2019 Speccy DemOz
Κάθομαι και ψάχνω καινούργιες παραγωγές για ΖΧ Spectrum. Όμορφα d3mOz, όμορφα παίζουνε. Φορτώνω όλο το αρχείο στον ZX Nuvo και ταξιδεύω...Το μάτι πέφτει σε κάποια ιδιαίτερα, απίστευτα, ανεπανάληπτα, απίθανα...
(1) PETSCII reader for Sinclair ZX Spectrum
D/L: http://www.pouet.net/prod.php?which=81649
Δεν είναι το καλύτερο, αλλά γέννημα θρέμμα Commodorian, θα το σχολιάσω πρώτο. Εξάλλου δικό μου είναι το thread, ότι θέλω γράφω...:p:lol:
Μου αρέσουν τα PETSCII grafX στον ΖΧ Spectrum! Zx Spectrum!; WTF? ...που λέμε και στο χωριό μου :lol:
18970
Τι είναι τούτα εδώ τα κόλπα ρε; Για να πατήσω ένα πλήχτρο (!)
18971
18972
18973
18974
Έχει κι άλλα. Κάποιος στο pouet.net σχολιάζει: "Κάθε 8bit πλατφόρμα, πρέπει να διαθέτει PETSCII" Συμφωνώ.
Τι μας λέει ο ποιητής;
  • carlosanta
    It was a long time that I was designing a "C64 simulator" for ZX Spectrum, the weird idea had been spinning in my head for several years now, but when a few weeks ago my friend Francesco published his font "Sinclair" for C64 he gave me the urge to lose a few more nights of sleep to finalize my suspended work for years.
    The way to handle the character set is quite different between C64 and ZX Spectrum. On the C64 there are two character sets, consisting of 128 characters, one with all the PETSCII symbols and only the uppercase characters (default) and the other set with uppercase and lowercase alphabetic characters and a reduced PETSCII set, the two font-sets they are alternative and cannot be used simultaneously. The ZX Spectrum instead uses only one set of 96 characters with alphabetic and uppercase letters and relegates the possibility of graphic characters to a set of 16 non-editable characters (the set of 4 × 4 pixel blocks) and “n” set of 21 characters redefinable mapped from A to U called "UDG" (User Defined Graphics). The different UDG sets can be used by selecting them with a POKE and once printed they do not change, so you can define a number of characters according to the available memory, to create the complete set of all the characters PETSCII + uppercase and lowercase set I used 3 banks of UDG characters in addition to the set of 21 basic characters.
    Once the complete conversion of the charset is over, since "the appetite comes with eating" why stop? I then gave birth to the idea of creating an automatic PETSCII ART converter that was built for C64. For this purpose I have specifically created a second set, restricted, only for uppercase characters and complete PETSCII graphic character sets but which also corresponded as sorting to the original C64 charset in order to facilitate the conversion of the ASCII codes of the characters.
    There was also to solve the problem of color conversion, the Commodore 64 has 16 different colors while the ZX Spectrum manages 8 colors with two brightness levels (Bright 0 and 1) but the black does not change between the two levels therefore the total of the colors on ZX Spectrum is 15. Furthermore the two palettes are VERY different chromatically.
    For the conversion of PETSCII ART into binary files I used the PETMATE program. The files are saved in binary format, the structure is very simple, they are files of 2002 bytes: the first byte defines the border color, the second the background color (paper), followed by 1000 bytes to define the 40 × 25 characters of the drawing and another 1000 bytes for the colors (attributes).
    Everything was developed with BORIEL BASIC, a BASIC compiler compatible with SINCLAIR BASIC but which also provides the most modern BASIC dialect structures and also allows to include Z80 assembler parts directly "inline".
    At the attached link you can download the program "ZX64 Simulator" containing the complete set of PETSCII characters with direct correspondences to the ZX Spectrum set and therefore usable normally in SINCLAIR BASIC and the PETSCII SLIDE SHOW which instead has a charset ordered with correspondence to the C64 set to allow a simpler conversion of PETSCII ART, the slide show in executable TAP format already contains 10 PETSCII ART.
    Always in the attached link you will find the complete listings, they are commented so it should be easy enough to understand the sources.
(2) Megademica 4K
D/L: http://www.pouet.net/prod.php?which=81065
18975
18976
Τώρα τι να πω γι αυτό;
Κανονικά :emoji_point_right:αυτό έπρεπε να πάει πρώτο, τουλάχιστον στην δική μου λίστα προτιμήσεων. Δεν είναι τυχαίο που απέσπασε (με ειρηνικό τρόπο :p ) την πρωτιά, στην Revision 2019 ,στην κατηγορία "Old school intro".
Τι έχουμε εδώ;
4K intro compo / ZX Spectrum 48K +AY
Idea, code, gfx by SerzhSoft,
Music by Gasman
Μετά από έναν θαυμάσιο, visual καταιγισμό, μετά μουσικής συνοδείας παρακαλώ, με το κλείσιμο της αυλαίας, η συνθετική φωνή του Speccy (!) μοιράζει greets σε Amigaaaaaa - Atari - Commodore, όλα με διαφορετικό pitch και επαναλαμβανόμενα αρκετές φορές, για να συνειδητοποιήσουμε τι έχουμε μόλις ακούσει.
Για Απίστευτα - Υπερσυμπιεσμένα γούστα! Δείτε το, σας παρακαλώ, σε πραγματικό μηχάνημα.
(3) GABBA
D/L: http://www.pouet.net/prod.php?which=83539
18977
18978
Αν σας αρέσουν τα χορευταράδικα demoz, εκείνα δηλαδή που μέσα τους εμπεριέχουν σκηνές animation με φιγούρες που λικνίζονται υπό τους ρυθμούς της όποιας μουσικής υπόκρουσης, τότε αυτό το demoυδάκι είναι για εσάς (όπως και για μένα). Φυσικά οι χορευταράδες δεν είναι ο μόνος λόγος για να το κατεβάσετε και να το τρέξετε στο -πραγματικό- σας μηχάνημα. Είναι πολύ φρέσκο, αφού παρουσιάστηκε στο CAFe (της χαράς :p) 2019, αποσπώντας την δεύτερη θέση, τον Οκτώβριο του 2019.
Το έτρεξα πολλές φορές στον ZX Nuvo και πάντα προς το τέλος κολλλλλλλλλάει σε έναν απίθανο τύπο που είναι έτοιμος να ρίξει μια εναέρια τούμπα.
18979
Δεν ξέρω τι συμβαίνει και ο τύπος κοκαλώνει (μπας και το σκέφτεται και το μετανιώνει; ;) ) ,αλλά αυτό δεν θα μου στερήσει επ' ουδενί την χαρά να το δω και να το ξαναδώ. Εξάλλου υπάρχει πάντα και ο ΥιουΤούμπης, ο κονσέρβας (Ιδανικός πυροσβέστης τέτοιων καταστάσεων)
Ξεκινάμε με υπόκρουση ABBA και μια γαλήνια, ασπρόμαυρη, συμβολική εικόνα μιας ήρεμης παρέας, βγαλμένης απ' ευθείας από τα 70s. Μετά από λίγο αρχίζει το γλέντι με γεωμετρικά σχήματα που αλλάζουνε θέσεις και χρώματα ενώ ταυτόχρονα τους αλλάζουν τον αδόξαστο υπό teknατζίδικη μουσική υπόκρουση. Μα, δείτε το! Τι περιμένετε;
Ένα μικρό δωράκι. Όλα τα όμορφα του 2019, εδώ :emoji_point_down:
Περιμένω και τις δικές σας προτιμήσεις.
  • 2019.zip
