Atarisid VI
...ή αλλιώς ένας SID emulator για τα 8bit Atari!
Θεέ μου πόση φαντασία έχουν αυτοί οι προγραμματιστές και τι άλλο θαυμαστό θα δούμε ακόμη να ξεπηδάει μέσα από τα κυκλώματα των παλιών μας 8bit !!! :)
Δημιουργός του ο Ivop (από atariage forum....)
Atarisid is a software emulation of the SID soundchip used in the Commodore C64.
Recently, a conversation with wrathchild got me interested in atarisid again and here's the result.
What's new in version 6?
- Use three pokey channels instead of one
- Newly calculated wave forms
- Higher fidelity and dynamic range (over 21dB per channel)
- Use pokey noise generators for a much cleaner sound and different frequencies of noise
- Disables basic at startup
- 34 new songs for a total of 64 (which is not a coincidence :))
Adam Gilmore - Ninja Commando
Adam Gilmore - Zybex
Ari-Pekka Paljakka (Zardax) - Retrograd
Ben Daglish - Bulldog
Ben Daglish - Cobra
Ben Daglish - The Vikings
Ben Daglish - Thing Bounces Back
Chris Huelsbeck - Metro Dance
David Whittaker - Glider Rider
David Whittaker - Loopz
David Whittaker - Speedball
Hein Holt (Hein) - Alien Seahorses Invading Heaven
Jens-Christian Huus - No Filter
Jeroen Tel - Alternative Fuel
Jeroen Tel - JT42
Jeroen Tel / Maniacs of Noise - Alloyrun
Jeroen Tel / Maniacs of Noise - Cybernoid
Jeroen Tel / Maniacs of Noise - Cybernoid II
Jeroen Tel / Maniacs of Noise - Hawkeye
Jeroen Tel / Maniacs of Noise - Ice Age
Jeroen Tel / Maniacs of Noise - Kinetix
Jeroen Tel - Myth Mix
Jeroen Tel - Noisy Pillars
Jonathan Dunn - Ocean Loader 4
Lasse Oorni (Cadaver) - Aces High
Lasse Oorni (Cadaver) - Escape From New York
Lasse Oorni (Cadaver) - GoatTracker Example (MW1 Title)
Lasse Oorni (Cadaver) - Metal Warrior
Lasse Oorni (Cadaver) - Metal Warrior 2
Lasse Oorni (Cadaver) - Nintedo Metal
Lasse Oorni (Cadaver) - Tarantula
Lasse Oorni (Cadaver) - Unleash The Fucking Fury
Mark Cooksey - Battle Ships
Martin Galway - Ocean Loader 1
Martin Galway - Ocean Loader 2
Peter Clarke - Ocean Loader 3
Reyn Ouwehand - What Have I Done To...
Rob Hubbard - Chimera
Rob Hubbard - Commando
Rob Hubbard - Crazy Comets
Rob Hubbard - Delta
Rob Hubbard - IK+
Rob Hubbard - International Karate
Rob Hubbard - Lightforce
Rob Hubbard - Monty On The Run
Rob Hubbard - Ninja
Rob Hubbard - One Man And His Droid
Rob Hubbard - Sanxion
Rob Hubbard - Spellbound
Rob Hubbard - The Master Of Magic
Rob Hubbard - Thing On A Spring
Rob Hubbard - Warhawk
Stellan Andersson (Dane) - Escape From Reality
Stellan Andersson (Dane) - The Slap Mix
Thomas E. Petersen (Laxity) - Freeze
Thomas E. Petersen (Laxity) - Highscore
Thomas E. Petersen (Laxity) - Syncopated
Thomas E. Petersen (Laxity) - Wisdom
Thomas Mogensen (DRAX) - Scarlet
Thomas Mogensen (DRAX) - Spunk
Timo Taipalus (Abaddon) - Hamlet
Tomas Danko - Groove
Torben Hansen (Metal) - Ramloesa
Volker Meitz (PRI) - Pool Party
Τα καταφέρνει ΠΕΡΙΦΗΜΑ !!! Δείτε και μόνοι σας :sneaky:
Από εδώ μπορείτε να κατεβάσετε την "εικόνα" .xex και τον πηγαίο κώδικα
http://atariage.com/forums/topic/259038-atarisid-vi/
Ευχαριστώ τον Nemo που μας ενημέρωσε έγκαιρα και έγκυρα...
http://www.mame.gr/forum/viewtopic.php?f=10&t=6059
Δε θα μένει CPU time για τίποτα άλλο! :D
Μου είχε διαφύγει αυτό! Πολύ καλό emulation όντως!!!
Δοκιμάστηκαν τα περισσότερα και δουλεύουν μια χαρά! Βέβαια για όποιον έχει μεγαλώσει με το SID υπό μάλης, θα του φανούν κάπως (σαν ψιλοχαλασμένο SID) αλλά παρόλα αυτά με τίποτα δεν μπορεί να επισκιαστεί η προσπάθεια!
