Mortal Kombat HD!
Amiga500
Ελπιζω επιτελους να το εχουμε στα χερια μας το 2019 (εκτος κι αν φανε copyright infringement) γιατι η δουλεια που εχουν κανει μεσω της Unreal engine 4 με νεα ξαναφτιαγμενα μοντελα μαχητων (και backgrounds) ειναι εκπληκτικη!
"A pixel perfect arcade remake of the original MK Trilogy using new 3D models created from all the original Mortal Kombat games and from all the Behind The Scene clips. From the massive scale of the project, it seems that all elements including test your might, various stages, fatalities, animalities, and more are being recreated from the ground up following the original sources as closely as possible."
Amiga500
Wow! Nice find! Πολύ ενδιαφέρον!
Υπαρχει μεγαλη πιθανοτητα φιλε nicked να "κρυβεται" και επισημη συνεργασια με την WB και να το δουμε officially!
"And for those going, “Well, it’s a fan project, WB Games is going to shut it down so hard,” hold on a second. Because apparently they’re an actual company, based on what a project lead said, and that it could very well be in partnership with the publisher.
When someone asked, “I know your are not releasing more images and info about the project here. And that you created a studio. Does this means you're going to a legal path, meaning you cannot use Mortal Kombat name and content? So, you're making another game based on MK and this project of an unofficial remake is dead?” The project lead simply replied, “I legally can't comment on this until early 2019.”
Ακόμα καλύτερα! Προσωπικά θα το 'τιμήσω' αν βγει κάτι ολοκληρωμένο!
