Games have no region codes so go wild with japanese releases. (But do keep in mind the 50Hz/60Hz settings if you use an older monitor to play)
The Japanese version of Metal Gear being the only exception, it only works on Japanese machines.
Εσείς το ξέρατε?The MSX uses the standard 9-pin port so most Amiga/C64/Sega controllers do connect but the pins are in a different order, so don't go there unless you are handy with a soldering iron!
nkary said:Games have no region codes so go wild with japanese releases. (But do keep in mind the 50Hz/60Hz settings if you use an older monitor to play)
Η απάντηση στην ερώτηση μου. Επίσης ανακάλυψα και ότι
