Remixes...Μυστήριες Εκτελέσεις...Μουσικές αλχημείες !
GoatTracker to Rob Hubbard music converter.
Tool to write music in Rob Hubbard's music driver using Goat Tracker. (rather than by hand in assembly like Rob did) The player used is from Monty on the Run hence the familiar instruments. (adapted from the documented source out on the net)
** This was purely a coding exercise, won't be publically released.
-"smart" buzzer support for AY player
Last bit of work on the AY player, focussing on the 'buzz' envelope effect. Now if two channels are free it uses the second channel to play the harmonics of the buzz envelope. The second channel uses a triangle wave with sync & ringmod enabled so the root tone can be modulated to create the effect. It's not hugely accurate (pretty impossible to emulate that sound in software) but for bass sounds it gives it that 'bubbly'-ness that most buzztone tunes have.
Ωπ τι Μαματος player είναι αυτός τώρα τον πήρα πρέφα!!!!
COMMODORE 64 EDLIB 2.01 D00 PLAYER (DOS OPL TRACKER) v0.20
C64 code by Mr.Mouse/XeNTaX for the SFX Sound Expander (SFXSE) peripheral
Kickassembler source code, using Relaunch64 as IDE.
Based on JCH's original Edlib Tracker x86 code
Email: mr.mouse@xentax.com or info@xentax.com
The readme has the following chapters:
* Contents
* Usage
* Summary
* Main routines/Other routines
* Acknowledgements
Contents:
This zip file contains:
* vibrants_fm.d64 (Commodore 64 disk image)
* edlibv200_player_v020_release_jul2017.asm (Kickassembler source code)
* readme.txt (this file)
The D64 file containts:
* VIBRANTS FM, the music collection, that uses the Edlib Tracker D00 player code I created.
* D00PLAYER02, the player for D00 files (INIT $1000, PLAY $1003).
Usage:
You know the drill, if you have an SFX Sound Expander, then run it on actual hardware.
If you don't, run it on WinVICE 3.1. Make sure you select the SFX Sound Expander:
go to Settings->Cartridge/IO Settings->SFX Sound Expander Settings and enable it. You can choose
between YM3526 or YM3812. The original hardware has YM3526.
XeNTaX,
Website: http://www.xentax.com or http://c64.xentax.com
Vibrants FM ( Xentax ): Μια συλλογή από 10 OPL1 (Adlib) Tunes που μπορείτε να απολαύσετε σε C64 με SFX Sound Expander
Πηγή >>> http://csdb.dk/release/?id=157163
Υ.Γ. (Αν το Commodore's SFX expander cartridge σας θυμίζει κάτι είναι ίσως λόγω της αναφοράς >>> εδώ )
Enchanted Land - Atari ST - Music Cover by Kaktus​
Saboteur 2 - Amstrad CPC (music Cover by Kaktus)​
Reyn vs Martin Galway - Wizball​
Platoon - Atari ST (Music cover by Kaktus)​
