VecFever for Vectrex by Thomas Sontowski
Και να που ήρθε το πλήρωμα του χρόνου και μόλις τώρα ο Thomas μου έδωσε το πράσινο φως να ρίξω φως στο μυστικό project που δούλευε πολύ καιρό τώρα!!!
Πρόκειται για μια cartridge που θα απογειώσει ότι ξέραμε μέχρι τώρα για την μαγική αυτή κονσόλα...
Για να μην μακρηγορώ, ορίστε μια πρώτη λίστα των χαρακτηριστικών του VecFever:
VecFever specifications:
- Ιncorporates 16MB memory that acts as a normal USB disk when plugged into a computer
- Compressed binary support to reduce filesize
- Allows convenient access of files using a built-in file browser with full ASCII fonts, long filename support, automatic sorting of filenames etc.
- No patches needed - all Vectrex cartridges work verbatim
- Switching between menu and cartridge always possible via reset button
- Includes a full version of 'Robot Arena', including storage of hiscore and options
- Multiple extra features for VecFever-aware cartridges, e.g. permanent storage of up to 4K per cartridge, global calibration parameters for faster drawing capabilities and a multi-bank extension allowing 4095 32k-banks per cartridge.
- Customizable: the entire menu can be loaded from disk allowing updating or changing the capabilities and look of the VecFever. It comes with three versions to choose from: the in-built gamer menu, an 'expert' menu with a lot more options and a special 'developer' menu for even more options geared towards developers including a ramdisk mode for developers to allow uploading and testing of up to 64k binaries immediately on a Vectrex via USB
+ Hiscore option
The VecFever allows via one global option to convert known, 'normal' cartridges into VecFever cartridges that include full hiscore tables with eight entries plus the entry and display capability in-game. The goal always was to convert the games in a way that during normal gameplay not a single cycle was changed, only after gameplay the 'game over' part was taken over and a hiscore entry/display was added so that the scores are comparable to 'normal' carts.
The menu also allows displaying/managing and customizing these hiscore tables - and there is not only one hiscore table per game, there are named hiscore tables for each gamemode and 1P/2P games, too, if wanted.
Right now this option converts about 30+ games, most vintage ones and quite a few homebrews....
Είμαι πάρα πολύ ευτυχής γιατί παρακολούθησα την πορεία του VecFever από πολύ κοντά και φυσικά θα είμαι μεταξύ των testers που θα παραλάβουμε τα πρώτα κομμάτια για ενδελεχή έλεγχο στις κονσόλες μας.
Όπως καταλαβαίνετε, δεν πρόκειται για μια απλή flash cart. Υπάρχει build in cpu. Υπάρχει τεράστιο απόθεμα 16 MB RAM. Υπάρχει μια πλήρη βελτιστοποιημένη τεχνική bank switching που θα μας κάνει να παραμιλάμε γιατί θα δούμε "cartridge" files μεγέθους 1024 KB!!!!....Υπάρχει πρόβλεψη για πολλά καλούδια που θα έρχονται σιγά-σιγά και θα προστίθενται στις απεριόριστες δυνατότητες του Vecfever, που από ότι γνωρίζω θα προσδίδουν χαρακτήρα "λειτουργικού συστήματος"...
Όπως θα δείτε στο video, μιλάμε για ενσωματωμένο jukebox (όταν έβαζα τα θέματα περί ΥΜ files είχα τον λόγο μου και κάπου στο όγδοο με ένατο λεπτό του παραπάνω video...από τα καλύτερα ξενύχτια της ζωής μου!), μιλάμε για ένα βασικό txt viewer, μιλάμε για video format που θα υποστηρίζει το VecFever και θα τρέχει στο Vectrex, μιλάμε....μιλάμε....μιλάμε για τα επτά θαύματα του κόσμου μέσα στο Vectrex !
Ακολουθούν λίγες ακόμη screens...
....Η διάθεση του θα αρχίσει γύρω στα Χριστούγεννα...
Να κάνω κι ένα μικρό update. Οι πρώτες 10 cartridges είναι έτοιμες. Από Δευτέρα περιμένω τη δική μου...
Έχει γίνει επίσης αναβάθμιση στο firmware και μεταξύ άλλων θα μπορεί να γίνει driving σε ένα 3-color led, "καρφωμένο" σε έναν από τους 3 gpio headers της πλακέτας (που προβλέπουν μελλοντικές εσωτερικές επεκτάσεις). Έτσι λοιπόν τοποθετημένο μέσα σε διάφανη (acrylic) cartridge case, θα μπορεί να γίνει ακόμη και "φωτορυθμικό" ακολουθώντας τον ρυθμό από τα μουσικά κομμάτια που θα παίζει το ενσωματωμένο jukebox player :cool:
Εδώ θα βρούμε κάτι πολύ ενδιαφέρον:
http://vide.malban.de/the-fever-is-ther ... speechless
ΗΡΘΕ!....ΗΡΘΕ!....ΗΡΘΕ!!!!!!
No5 JuSt LaNdEd
Μαζί με τρομερή συνοδεία!!!!!!!!
Ήδη το firmware, έχει γίνει update (1.01)....
Αυτή την στιγμή προσπαθώ να συνέλθω από το αρχικό shock και θα επανέλθω
Ωωωωωωωωωωωωωω!Άργησε λίγο αλλά το πήρες!!!!! Περιμένουμε φωτοσουτ :) :) Καλορίζικο! :D :D
Πωωωωωωω!!! πωωωωωωωωωωωωωω!!! :geek:
ΑΨΟΓΟΣ ARM2 βλέπω AΓΡΙΑ ΓΟΥΣΤΑ περιμένω εντυπώσεις.... μην αργείς....
Λοιπόν ξεκινάω...
Μπήκε σε κομψή, διάφανη acrylic case και κολλήθηκε επίσης custom label δικής μου έμπνευσης. Αυτή, μαζί με 5-6 ακόμη ήταν κάποιες προτάσεις μου προς τον Thomas, που φαίνεται να προτιμά την συγκεκριμένη.
Το μόνο που είχα να κάνω είναι με τη βοήθεια του Dremel, μια μικρή και διακριτική USB έξοδο
Ένα από τα πολυάριθμα χαρακτηριστικά του VecFever, είναι το προγραμματιζόμενο led που με τις χρωματικές του εναλλαγές, δίνει ...άλλο χρώμα στις homebrew δημιουργίες. Θα επανέλθω με όμορφο video...
Όλες οι αποχρώσεις του γκρι...εεε....του led ;)
Ένα από τα χίλια - μύρια χαρακτηριστικά του VecFever, είναι το multicoloured led που μπορούμε να το 'οδηγήσουμε' με έξυπνο προγραμματισμό, ώστε να ακολουθεί κάποια εφέ του παιχνιδιού που επιθυμούμε να δώσουμε έμφαση.
Κοιτάξτε λοιπόν τι γίνεται με την ειδική έκδοση του Head On (που μαζί με το Robot Arena, θα συνοδεύει το VecFever)
Για πρώτη φορά σε Vectrex !..... :thumbup:
Ωραία πράγματα. Geo αν πέσει κάνα vectrex στην αντίληψη σου…… ;)
antnik said:
....αν πέσει κάνα vectrex στην αντίληψη σου…… ;)
...Θα το κρατήσω κι αυτό για μένα...Χα!Χα!Χα!Χα! :lol: :lol: :lol: :lol: :lol: :p
Μεταφορά αρχείων από το PC στην κάρτα και αντίστροφα...
Υπάρχουν 2-3 τρόποι για να μεταφέρουμε τα αρχεία μας στο VecFever και να τα χαρούμε σε real Vectrex.
Ο πιο κοινός τρόπος για όλους εμάς τους απλούς χρήστες είναι να το χρησιμοποιήσουμε ως απλό USB stick ή Pen Drive (αν θέλετε...)
Πως;
Μόλις το συνδέσουμε στην USB του υπολογιστή μας, αμέσως εμφανίζεται ως συσκευή αποθήκευσης
...με περιεχόμενα...
...και λίγο video...
Υπενθυμίζω ότι μπορούμε να φορτώσουμε τρία διαφορετικά είδη MENU.
GAMER -> για τους απλούς χρήστες που επιθυμούν μόνο να παίξουν και να δουν τις roms που διαθέτουν
EXPERT-> με πιο προχωρημένες ρυθμίσεις και περισσότερες επιλογές παραμετροποίησης του MENU ...
DEVELOPER-> Για προγραμματιστές. Σε αυτή την περίπτωση προσφέρεται ramdisk και μέσω του VecFever, μπορούμε ταχύτατα να μεταφέρουμε το πρόγραμμα μας και να το ελέγξουμε στην κονσόλα. Αν χρησιμοποιήσετε το VIDE, τότε καλό είναι να ρίξετε μια ματιά εδώ:
Παρατηρείστε το δεύτερο video και δείτε πόσο εύκολα μπορείτε να μεταφέρετε on the fly το πρόγραμμα σας! :thumbup:
Ένα μικρό update...Αύριο, μεθαύριο αναμένονται 4 καινούργια πλακετάκια ελαφρώς αναβαθμισμένα σχεδιαστικά. Αυτή είναι η 6η έκδοση από τότε που ξεκίνησε το project. Οι βελτιώσεις αφορούν τον σχεδιασμό του pcb, ώστε να χωρά άνετα, ακόμη και στις καινούργιες cases. Δεν υπάρχει καμία αλλαγή στην λειτουργία και στο λειτουργικό σύστημα. Μετά από αυτό και εφόσον όλα πάνε καλά, το VecFever θα μπει σε κανονική παραγωγή και διάθεση με αρχική πρόβλεψη για 100-150 κομμάτια.
Ο καιρός γαρ εγγύς
Με φτιαχνς......πρωί πρωί.
Δεν μας έφταναν τα ανοιχτά προτζεκτάκια στον πάγκο.... θα ξεκινήσουμε και άλλα
(βρε λες? ;) )
Απίθανη η θήκη σου Geo!
Έχει δική του CPU αυτό το πράγμα ε;
Έτσι ήταν κάποτε και τα disk drives για τα home μας! Δούλευαν σαν ανεξάρτητα computers σε σύνδεση...
Βλέποντας αυτό το απίθανο led (νομίζοντας ότι η υποδοχή του ήταν στο πίσω μέρος του Vec), είπα ότι το vectrex απέκτησε led οπίσθιας προβολής (δε ξέρω αν το λέω καλά, θυμάσαι κάποιες tv που φώτιζαν τον τοίχο πίσω τους, προσφέροντας ξεκούραστο contrast;).
Πάντως η αλληλεπίδραση του Led είναι σουρίαλ! Το λάτρεψα!
Μόνο εγώ και ο Thomas, έχουμε τέτοιες θήκες! LOL! Η αλήθεια είναι ότι είχα στοκάρει δυο και τη μία του την έστειλα δώρο. Οι συγκεκριμένες έχουν σταματήσει να παράγονται εδώ και καιρό. Τελευταία γίνεται μια ακόμη προσπάθεια στο FB, αλλά δεν βλέπω να συγκεντρώνεται ο απαραίτητος αριθμός ενδιαφερομένων προκειμένου να ξεκινήσει η παραγωγή...
Ναι, είναι εφοδιασμένο με τον δικό του ARM processor (+RAM) χαρακτηριστικά που το κάνουν να πετάει :)
Τελικά ο Thomas δεν θα συμπεριλάβει τα leds και θα το διαθέσει μέσα σε κανονικά, αδιαφανή cases.
Τα leds είναι μόνο για πολύ περιορισμένα κομμάτια, για πολύ στενό κύκλο φίλων του +developers (20 στον αριθμό) γι αυτό και τα serial numbers θα ξεκινούν έχοντας ως βάση το 20άρι.
Αυτό ήθελε να διευκρινιστεί για να μην υπάρχουν παρεξηγήσεις. Σεβόμενος την επιθυμία του, άλλαξα ακόμη και την περιγραφή των videos που ανέβασα...
First, I would like to clarify that this is my own special 'VecFever' version that it may or may not be available at a later date.
LEDs are really meant to be for testing purposes. This is the reason Thomas (the developer) added this feature initially.
Υπάρχουν και άλλα πάρα πολλά, που όμως υποσχέθηκα ότι θα αποκαλύψω μόνο μετά την επίσημη διάθεση...
Δεν θα ήθελα να χαλάσω το γλέντι με την φλυαρία μου (...που πάνω στον ενθουσιασμό μου καμιά φορά παρασύρομαι και δεν έχω μέτρο...), έτσι δεν είναι; :sneaky:
Που να φανταστώ ότι στο απο κάτω post κυριολεκτούσες!!! :D:D:D
Και να που ήρθε το πλήρωμα του χρόνου και μόλις τώρα ο Thomas μου έδωσε το πράσινο φως να ρίξω φως ...
Τις τελευταίες μέρες υπάρχει μεγάλη κινητικότητα...Θα αρκεστώ σε ένα copy/paste του μηνύματος του Thomas από εδώ
Hi,
just a quick status update: the firmware itself has been finished around Christmas, although the menu(s) can be updated afterwards anyways.
The pcb underwent a few iterations, mainly so that it fits perfectly in a 'normal' Vectrex enclosure (the ones I've got (original, several repro ones)
do differ a bit) and the last, current one really seems to be perfect. No problems have been unearthed by testers so far, and it has been used on dozens
of Vectrex units so far (at least 20 by me alone). So that's good.
There are still problems with getting the USB-opening into the case by the local company I've tried to use for the laser-cutting until now. And I really didn't
like the printed labels initially so a completely different, very simple b/w backup-redesign has been printed. This one I do like a lot actually so I'll probably use
it.
So.. all hinges on the cases in the moment,
Thomas
Μόλις πληροφορήθηκα ότι σε 1-2 εβδομάδες οι πρώτες πλακετίτσες του VecFever θα μπουν σε διαδικασία παραγωγής...Θα ενημερώσω με νεότερα!
